Rear Main Seal
Rear Main Seal
I am replacing my rear main seal and I am having problems finding torque specs for the rear cover. Does anyone have the torque specs for the cover. Is it necessary to torque the bell housing down or not. I am also putting in a Twin Disc and was wondering what the torque specs are.
I can shift faster than you.
Rear cover bolts are 18 lb-ft, and the two long 10mm bolt attaching the oil pan to the rear cover get 106 lbs-in. The bellhousing bolts get 37 lb-ft, but snug has always worked for me.
