What should I run with this combo PP 5.3 and more
PP S2 5.3 heads, cartech, 224/228 586 596 114 114 cam, 3:73 gears, LS6 intake, longtubes with x pipe & true duals, ASP pulley, 30lb injectors and a TNT 100 shot.
Should I be in the 11s on the motor and can I hit 10s on the spray with traction? I can see a 9inch in my future
Justin
Justin
LS1TECH Sponsor
its possible but for one he'd blow his stock rear before that would happen i believe since hed probably have to spray off the line...that and its alot harder to go faster once you get into the 11's...i would think hed have to up the shot to get into the low 10's but this is all benchracing so who knows...get to the track and see what itll do...bring back pics of the carnage when your done though
LS1TECH Sponsor
Originally Posted by Tally TransAm
i went 12.04 @ 120.3 with a similar setup (NA) on a 2.03 60's
i figure with slicks and gears i could probably drop .6-.8 off that
lata
Bill
Originally Posted by foff667
its so hard to compare auto vs manual cars though they are two different beasts...hes got a 3800 stall and with traction could scrape into the 1.59 60' area so right off the bat with nothing else according to that hed have you beat by 4 tenths and probably 8 tenths at the top end with less hp to the rear wheels so its really hard to compare even they they are the same body/engine.
lata
Bill
lata
Bill
