Ls1 427?
Old 10-21-2010, 03:16 PM
LS1TECH Sponsor
Steve - Race Eng's Avatar
Default LS1 vs. LS6
The LS1 blocks have solid main bulkheads, no breather holes. The LS6 blocks have windowed mains for breathing making the block much weaker for MID sleeves. There is a possibility of the block cracking between the sleeves if the larger bore sleeves are installed. I'm not saying they will crack, just that I feel uncomfortable pushing these LS6 blocks with the larger bore sleeves.
The LS6 block photo is an MID sleeved block I just finished. This will be a 4.155" bore deal.
The Gen IV blocks have breather holes as well but they are different in that the coolant jacket has been raised considerably. This leaves more material below where the MID sleeve seats making these blocks acceptable for bores to 4.200". Most guys still stay at 4.185" for ring availability reasons.
The guy that doesn't like sleeved blocks must have had one done by a clueless shop.
Steve
Attached Thumbnails Ls1 427?-ls1-main-bulkhead.jpg   Ls1 427?-ls6-main-bulkhead.jpg
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old 10-21-2010, 07:11 PM
35thAnniversaryPhil's Avatar
Wow, this is extremely interesting. I had heard about it before but nothing like what you described it Steve. It appeals greatly to me for various reasons to re-sleeve an LS1 block to 427,454ci or whatever but also for a specific reason that no one has mentioned so far. One could keep their stock LS1/LS6 block that the car came with from the factory. Its still cool to think that way right? I think so.
Thanks for the info Steve
Old 10-21-2010, 07:44 PM
turbinesurgeon's Avatar
So how well do the 4.8/5.3 blocks due with the same sleeves? They can be had cheap, and with the cast iron block I bet they can handle quite a bit of abuse.
Old 10-21-2010, 07:53 PM
Zmg00camaross's Avatar
My thoughts also, and just looks like a heads and cam car
Old 10-21-2010, 11:08 PM
doylie24's Avatar
Thats what got me really interested in this route. Stock block with mean cubes. Nobody would know till you let a rip. Seems like a less of a headache goin this route because you won't need to change anything like in a ls2, ls3 and other engine swaps. Seems to me a bit cheaper too.
Old 10-21-2010, 11:23 PM
nodrok's Avatar
I know you can do it with a 5.3l but im not sure about the 4.8l ive seen pictures of 5.3l block 427's.
Old 10-22-2010, 03:15 AM
kmspruill242's Avatar
Steve, you did the Speed GT Volvo S60's blocks? They've turned out to be really competitive. I started out road racing a volvo at 16, still have a love for those cars.
I have a feeling we'll be seeing more sleeved blocks in the future...
Old 10-22-2010, 04:33 AM
9secondsflat's Avatar
Top engine builders like Ron Hutter (he built the engines for Dale Jr during his back to back championship wins and was 3x engine builder of the year) have tried every possible way to obtain longevity and bullet proof reliability from sleaving in an effort to increase cu of the engine....it has never lasted.
Old 10-22-2010, 04:48 AM
I dont know what the problem would be with sleeves? Hell large bore over the road trucks are sleeves and they can last a million miles. differnt enviroment I know.
Old 10-22-2010, 05:13 AM
csv033's Avatar
Seeing as where all talking about sleeving we might aswell make it informative.
What is the problem with sleeving asin longevity??
How are the sleeves fitted like asin what process holds them in place?
Whats the difference between wet and dry sleeves?
What warranty do you get if you get a resleeved block?
Im sure the op would want to know these before parting with any hard earned cash.
Old 10-22-2010, 07:53 AM
ok....lets see big over the road trucks that rev to 3000 rpms and was DESIGNED to run 500,000k miles from the factory vs a high winding small block.
I guess nascar will start a 500 mile race of 18 wheeler trucks to run at an average speed of 70 mph....yawn
Old 10-22-2010, 08:12 AM
  #32
sierrac3_s2000's Avatar
The 4.8l and 5.3l share the same block. The displacement difference is in the stroke of the crank. I too would be interested in seeing what you could do with an iron block.
Old 10-22-2010, 08:24 AM
  #33
darkvader0's Avatar
Steve
More valuable information I didn't know before and am glad I know now. Thanks.
So for us NA, 4.125" seeking guys with a 5-600rwp goal, should we worry about the LS1 block's coolant jacket and/or LS6 windowed mains in terms of lengevity?
FWIW I have been running a sleeved Honda block for almost 10 years and over 100k miles now. The car makes just under 600whp and I drive it nearly everyday. I used a place called Benson's that was around back then. Not sure what process they used to press in the sleeves, but it has worked well so far.
Old 10-22-2010, 12:27 PM
  #34
Like I said not a great comparison I know but still those trucks make mad torque and do run with a hard load. But I dont see why a properly worked block that have sleeves installed wouldnt be reliable. I just want some proof.
Old 10-22-2010, 08:51 PM
  #35
The Sad's Avatar
You have two extremes:
1. Diesel revving to 3,000 for 100's of thousands of miles
2. Cup car revving to 9,000 and staying at around that RPM for several hrs
Our cars are somewhere in the middle - revving to 6,000 on an occasional basis. If sleeves I can work in both extremes, it seems like they would be fine for the middle ground.
Old 10-23-2010, 06:35 AM
  #36
davidws6's Avatar
Default Sleeves
I wanted big cubes and did not want to put a brick of cast iron on the front end of my WS6.
So I probably spent a few more $ to retain the lighter aluminum.
I had Steve do a ls2 block with dry darton sleeves. Have had 0 problems with it.
Dude who assembled it said the machine work on the block was top notch.
Very small cam and made 560 at the wheels. If the fast intake was not on it, it would pass for a stocker.
Sorta wish I would have went with the MID sleeves for a 200+ shot. But for the power to weight ratio, it's scary enough !
Old 10-23-2010, 04:26 PM
  #37
LS6
LS6's Avatar
I like this thread
Very informative
Nice to read usefull expert feedback
I whish this thread to be sticky...
Old 10-23-2010, 08:53 PM
  #38
koolrayz's Avatar
ERL also does a lot of sleeved engines. Mine is a 5.3l aluminum block with a 4.125 bore 4" stroke. There are a lot of very fast cars running there sleeved blocks with NO issues. Hard to go wrong with ERL or Steve.
Old 10-25-2010, 12:18 PM
  #39
rednari's Avatar
This is for Steve. I am assuming you can use L92/LS3/LS7 square port heads on the Darton sleeved LS1 block because of the larger bore. This would be a requirement for an NA motor. Otherwise, you would have to FI the motor to provide the air a 454 needs.
Your thoughts and/or suggestions for the type of heads to use for this motor woulds be appreciated.
Old 10-25-2010, 08:08 PM
  #40
doylie24's Avatar
I would also like to know what selection of heads I could run on a sleeved ls1 427?
Quick Reply: Ls1 427?
