500RWHP stock bottom end, hydraulic roller, M6 LS1/LS6 recipe?
-UPDATED APRIL 2011-
From what I understand, from everything I've read and seen mostly in the "Dynamometer results and comparisons" section of LS1TECH, 500RWHP is possible on a stock bottom end, hydraulic roller, manual LS1/LS6 Camaro or Corvette without nitrous, forced induction or race gas. Tell me what you guys think and maybe share some heads and cam experience as well. I know this setup is on the extreme side but it has been proven to make the power. I would even go as far to say that its guaranteed to make 500RWHP.
This can only be done with manual 6-speed Tremec T-56 car.
EDIT: I stand corrected, Chris1313 with his 4-speed is making 522RWHP(INSANE!)
Certain parts should remain stock to help with power including:
-Aluminum driveshaft
-10-bolt rear-end
-3.42 gears
-Rims
-Tires
Guaranteed recipe for 500RWHP, stock bottom end, hydraulic roller, M6 LS1/LS6:
-Chris1313 ram air mod
-K&N oiled cotton filter
-104mm FastToys airlid
-No MAF/4" straight hollow pipe (Speed Density tune)
-FAST 102mm throttle body
-Tony Mamo ported FAST 102mm intake manifold
-Tony Mamo ported AFR 230cc V2 heads with XXcc chambers for XX.X:1 compression
-Cosmetic gaskets 0.0XX" MLS gaskets for 12:1 compression
-PatG spec'ed cam OR TSP Tsunami camshaft or some other all top end cam
-KOOKS offroad headers with 1 7/8" primaries and 3" out
-KOOKS offroad 3" true dual exhaust
-No AC
-No power steering
-Mezeire electric water pump
-ATI harmonic balancer with 25% underdrive
-Star Machine belt driven crankcase vacuum pump
-7000RPM OR + redline
-93/94 octane gasoline
-Razor shap professional tune done on a dyno
and voilą...500RWHP and maybe, just maybe, a little more
lol
*Also, the torque should be at around 425 to the wheels
-10-bolt rear-end
-3.42 gears
-Rims
-Tires
-No AC
-No power steering
lol
Last edited by 35thAnniversaryPhil; 04-16-2012 at 09:43 AM. Reason: Just got a crazy new idea!
remove the a/c and power steering? no thanks lol.. You could get 500hp with a cam heads and nitrous and keep that ****. I think at that point I would just do work to the bottom end. Plus, the stock 10 bolt isn't going to hold that much power for more than 1 pass lmfao..
From what I understand, from everything I've read and seen mostly in the "Dynamometer results and comparisons" section of LS1TECH, 500RWHP is possible on a stock bottom end, hydraulic roller, manual LS1/LS6 Camaro or Corvette. Tell me what you guys think and maybe share some heads and cam experience as well. I know this setup is on the extreme but it has been proven to make the power.
-10-bolt rear-end
-3.42 gears
-Rims
-Tires
Recipe for 500RWHP, stock bottom end, hydraulic roller, M6 LS1/LS6:
-Ram air mod
-Some air filter that barely holds anything back
-TSP 100mm MAF
-Ported FAST 102mm manifold
-PRC 227cc heads with 57cc combustion chambers to get that compression up to 11.4:1
-thinner 0.045" MLS gaskets to get that compression up to 11.5:1
-TSUNAMI camshaft or some other all top end cam
-KOOKS headers with 2" primaries and 3.5" out
-No cats, no mufflers, jump dump it after headers
-No AC (Optional)
-No power steering (Optional)
-Underdrive pulley
-7000RPM redline
-93 octane gasoline
-Some anything but conservative extreme pro tune
lol
-10-bolt rear-end
-3.42 gears
-Rims
-Tires
-Ram air mod
-TSP 100mm MAF
-No AC (Optional)
-Underdrive pulley
-7000RPM redline
-93 octane gasoline
lol
I dont think PRC will be in your mod list, no offense, and to do it reliably with hydraulic roller you are going to be precise with your lifter preload, and running GREAT valvesprings. Cam is going to be custom too...
Just a little food for thought....
LG Pros, Haltech Killer Bee II, TFS 215s (59cc), .040 Cometic gaskets, VR5X/Vindicator cam/G5X3 cam, EWP, SVO 32 or 42lb injectors, UD Pulley, Ported FAST 90/92/102, Ported LS2 TB, YT/HS roller rockers, 3in X pipe, 3in Catback and Torco.
i am running 500+ with a fast 90 ported and port matched to a 93 to amtch my new tb with a 224 114 cam .
the intake manifold usually restricts the best of heads that flow 290 or 300 since a stock fast is 270or 280 cfm . ls6 intakes flow like 260 if memeory serves . non ported of course .
all my port work from heads to intake etc.. are self done .
course have some experience doing this but i am certainly not the best i just learned from the best on this board .
proper size pushrods , gaskets , a lot of variables come in to play . free up as much power as you can cheat from the engine then research and put in the right kind of parts down to claying the pistons to make the most out of what cam to use .
for power a 114 cam makes more power and runs a higher mph when a 112 makes more down low and is good for the track . of course this is cam to cam . even valve lift of the cam comes to play when shaving , decking , gaskets then pushrods .
kind of like cooking , everything has to go together and a lot of reading and trying other things goes a long way .
just my .02
just my .02
I'm gonna get in on this
I got a 98 ss camaro ls1 s/c head work cam etc just had it on the dyno and it made 460 rwhp but I have a stock rear end how long you guys think that's gonna last at 4000 rpm on a m/t slick
I updated the list to include the new AFR 230cc V2 heads which are basically upgraded 225s.
I also mentioned that they have to be fully hand ported to further maximize their gains.
When the LS1 came out in 1997 in the Corvette and 1998 in the Camaro, people dreamed of pushing 425-450RWHP and only a handful of knowledgeable people could pull it off similar to PAT G and Tony. These days, it is common place and everybody can do it. Automatics are doing it for crying out loud!
The dream is now 500RWHP.
Will it some day become common place? Will it stop there?
500rwh
++ 1 On Pat G RECIPE !Also check out Chris1313 setup his car has gone 10.08Fast 102 setup .H/C with rod bolts.
You will need some good work on your heads & intake by Mamo or someone close to his level of talent ,Chris did his own work on his Fast 102 setup.
https://ls1tech.com/forums/generatio...heads-cam.html
After reading through the parts list of his "recipe" I have taken note of the parts that improved like...
-90MM MTI airlid VS 104MM FAST TOYS airlid
-102mm speed density VS 100MM TexasSpeed MAF
-FAST 90MM VS FAST 102MM
-FAST 90MM throttle body VS FAST 102MM throttle body
-AFR 205cc VS AFR 230 V.2
-Custom cam VS More potent off the shelf cams like the TSP TSUNAMI for example
-KOOKS 1 3/4" headers VS KOOKS 1 7/8" headers
-Y pipe with 4" merge VS KOOKS OFFROAD 3" true duals catback exhaust system
So many new advancements since 2007!
I believe our car(4th generation f-bodies) have received an larger than usual push from the aftermarket forming an incredible list of aftermarket parts simply because there was no real successor except the GTO from 2004-2006.
What can we expect for the future say 2015?
