cam heads build ideas?
Old 11-03-2010, 09:33 PM
ws6wannab's Avatar
Default cam heads build ideas?
heres what i have bought 806 cnc ported heads with dual valve springs , 3.73 gears ,pacesetter longtubes, bbk ssi intake, k&n fipk intake,601 lift custom grind cam ,10 pound nitrous bottle with some lines and accessory spec stage one clutch sub-frame connectors hurst short shifter
plan on going with a differnt cam because im not sure all the specs on this one it was free what cam would be good for my mods ive been looking at the ms3 and not sure how big of a nitrous shot i should go with i plan on using a window switch also should i replace lifters i see alot of people go with the ls7 also what suspension upgrades should i do for the added power any feedback would be great only the intake is on the car right now
