water of radiator overflowing from overflow tank !!
Old 12-04-2010, 03:45 AM
Camaro ss 2001's Avatar
Unhappy water of radiator overflowing from overflow tank !!
Hi guys
im finding that after heating up my car that the water coming out of overflow tank then it leads to overheating!!!
My car is manual t56, the power streeing cooler is cracked cauz the oil is in radiator, i have changed the filling plastic cauz it had leaking too!
what may b the problem to cauz this?? is it heads gasket? or the heads? how 2 solve the problem
any advice will b helpful
thanx
Old 12-04-2010, 04:58 PM
csjta2's Avatar
Could be a simple as a bad Radiator Cap
Old 12-04-2010, 05:42 PM
SOMbitch's Avatar
Pressure test your cooling system and you will find the problem
Old 12-04-2010, 09:46 PM
09camaro383's Avatar
If your radiator cap is good Its most likely you have a bad head gasket
Old 12-04-2010, 10:04 PM
ae13291's Avatar
either a bad radiator cap or you overheated it enough to cause a bad headgasket.
Quick Reply: water of radiator overflowing from overflow tank !!
