What heads with VRX4 Camshaft 228/230 .588/.592 112 LSA?
Old 12-08-2010, 01:12 PM
Greekey's Avatar
Default What heads with VRX4 Camshaft 228/230 .588/.592 112 LSA?
Guys I've ordered a new camshaft and it should be here soon. I'm kinda stuck on what heads I should match them up with. I was looking at the Trick Flow 220 as cast heads at vengeance racing. Would they be a good match? What kind of milling job should I have done to them. I also will be getting a Fast102 intake manifold, fast rails, racetronix pump, and new injectors. Any input?
Old 12-08-2010, 02:52 PM
slt200mph's Avatar
Why don't you call Ron @ Vengeance and ask him...your going to use one of their cams. They have done a bunch of dyno testing with different combos and know what workd best. Ask a pro instead of a bunch of amatures on here.
Old 12-08-2010, 03:41 PM
Always2Slow's Avatar
The as cast 220cc heads cleaned up by Ron are an excellent head for that cam. The TFS heads are pretty forgiving when it comes to cams even though a vrx4 is no slouch. Should make good power with that setup. Talk to ron on how much you can mill.
Old 12-08-2010, 09:37 PM
desertLS1's Avatar
Another vote for TFS 220cc as cast heads. Call Ron up.
I'm personally running stock 243's right now, & plan on moving up to PRC stg 2.5 LS6's. Mainly because I'd rather stick with a stock style head casting. I hate the should I/ do I have to run aftermarket rockers debate.
Old 12-13-2010, 08:31 PM
Pipelayaz's Avatar
Let us know what you find out.
Old 12-14-2010, 12:46 AM
desertLS1's Avatar
^^^it says trickflow 220's in his sig.....
Old 12-14-2010, 09:24 AM
LSX Mechanic
Damian's Avatar
Trick Flows work well with that camshaft. On a 112+4 you can safely go to 61cc with no issues. Also make sure that the wipe pattern and pushrod length is checked correctly when installing TrickFlow/Yella Terras. Otherwise your power will fall like a ton of bricks @ 6400.
Good luck.
Quick Reply: What heads with VRX4 Camshaft 228/230 .588/.592 112 LSA?
