LG G5X4 and PRC stage 2.5 5.3 heads.. PTV issues?
Old 12-14-2010, 02:42 PM
bowtieguy72's Avatar
Default LG G5X4 and PRC stage 2.5 5.3 heads.. PTV issues?
I currently have the G5X4 cam in my car and just got a deal on some TSP PRC stage 2.5 5.3 heads i need to know if im going to have PTV issues, im thinking i may have to flycut, anyone else running this similar setup please chime in. Thanks
Old 12-14-2010, 03:44 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Yes you will need to flycut. The X4 doesn't have very good p/v so the larger valves will definitely require cutting. The only heads we can confirm will clear is the PRC Stage 1 LS6 heads & the PRC 215 heads.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 12-14-2010, 05:50 PM
Thanks matt i had a feeling i would have to fly cut, I originally wanted the PRC 215s or Trick Flow 215s but i couldnt pass up the deal on these 5.3s.
Quick Reply: LG G5X4 and PRC stage 2.5 5.3 heads.. PTV issues?
