degree cam or not
Old 01-06-2011, 03:47 AM
blocc monster's Avatar
Default degree cam or not
Who here degrees there cam? Is there a benefit doing so? Should i have the machine shop do it while there doin my motor, let me know.
Old 01-06-2011, 03:56 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
The general population of this site pretty much installs it straight up. What combo are you going to be running?
Old 01-06-2011, 04:29 AM
vettenuts's Avatar
I did mine. Ensures cam is installed per the cam card and can pick up if something is wrong with the grind. Also, while TDC is known it is a good time to check PTV.
Old 01-06-2011, 09:45 AM
KCS
Moderator
KCS's Avatar
I degree'd mine. It's a way to make sure the cam is correctly installed and will let you check piston-valve clearance as well, so it's pretty important to check. I've seen a 408 lose about 200hp because the cam was two teeth off. Stock motors aren't so lucky.
Old 01-06-2011, 10:17 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
^^These two guys above me nailed it. It's not a magical thing you do to make more power. It simply ensures the cam is installed as prescribed. If your timing set is machined incorrectly, or you install the cam a tooth off, you can be way down on power as well as run the risk of major piston to valve clearance issues! Degreeing is simply checking to make sure it is in there correctly!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 01-06-2011, 05:58 PM
mike c.'s Avatar
Seven cam swaps and never degreed one.
Old 01-06-2011, 10:12 PM
Thanks guys!
