What kind of power should this make?
10 Second Club + 14 Second Truck Club
395 stroker
10.9 : 1 cr
stage 2 ported ls6 heads (done locally)
flow
lift int exh
.100 76 59
.200 150 124
.300 214 180
.400 257 209
.500 287 229
.600 292 235
2.02 1.57 manley valves
5 angle valve job
manley springs w/ ti retainers
lunati 230/237 .565/.570 114lsa (custom ground 230/237 w/ more lift)
ls6 intake, flp lt headers, flp y-pipe, no cats, loudmouth
ported 80 mm bbk tb, 85mm maf descreened
2001, WS6, M6, 3.73, 12 bolt
10.9 : 1 cr
flow
lift int exh
.100 76 59
.200 150 124
.300 214 180
.400 257 209
.500 287 229
.600 292 235
5 angle valve job
I'll take a stab at it and say youll be around 460 RWHP. Thats only a moderate sized cam for the displacement you'll be running. Go larger and you should be able to knock on 500 RWHP's door without too radical of a setup.
