cant find oil leak
cant find oil leak
So my car recently started leaking oil occasionally. By occasionally I mean every few days it would leak, now it is starting to leak about everyday. I wiped it down and got it up in the air to see if I could find it by running it and checking the font cover, oil pan, filter, heads etc and cold not find it. It is somehow getting all over the betls and flinging oil everywhere so when it does leak i cant find it. The front cover oil pan, normal stuff etc lookd dry, all the pulleis/alternator etc are covered in oil along with the hood. When it leaks, it prolly only leaks maybe 2-3 ounces. Also, it is not the dipstick, oil cap on the head, or the pressure release ports on top of the heads that recirculate to the TB. When it dripps, it seems to drip in the middle front of the engine. It seems like it leaks worse when I top it off w/ oil and I make sure to keep it at 5.5-6 quarts. any ideas?
