abs/brake quesions
abs/brake quesions
I need some help. I have a 2002 camaro ss and as I was driving today the abs info light and brake light both came on. I kept going till I got home and once I did I turned the car off and back on and the lights were off. When I left again three hours later to go to class, the lights were on again. I am not sure if its ice because it has been getting warmer here in indiana and ice is melting. I have noticed no problems at all with braking so idk if I should take it in or what? Any suggestions on what I can do before taking it in? Any help will be appreciated.
I had the same problem with my '97Z. I kept thinking it was the worst possible scenario: ABS module gone bad, etc. I started by checking the rear wheel speed sensors and found they had almost a half inch of magnetically charged debris sticking on them, obviously fouling the reluctor readings. Check your wheel speed sensors before you go digging in too much...
