What head gaskets?
The 02 gaskets are different than the 98's. When I rebuilt my motor I used some Fel-Pro gaskets from O'reilly's.I have used them on many Ls1's with NO problems whatsoever.
TT-TECH Veteran
Go to SDPC and look at the write up on the use of head gaskets. They tell you that 98 and some 99's had a small half moon shape on their heads that would not seal with the 02 gaskets unless you are using heads from a later model. Just use the right gaskets for your year. They are a tad bit thinner also I believe 98=.056 02=.060. Good luck!
