Is there enough ptv clearance to run this cam 243 248 .613 .620 @110?
Can this cam be ran on stock heads with stock pistons or is there not enough piston to valve clearance? Its not much bigger then a trex.
thunder racing trex 242 248 .608 .612 @110
thunder racing custom 243 248 .613 .620 @110+4
Retard it 4* and degreed properly it might just clear on some engines. Might not be "safe" but it could "clear".
As is on 108 ICL, mill the heads and flycut will yield best results.
LS1Tech Premium Sponsor
I'd say it depends on one's definition of "clearing." Never over-rev it, never miss a shift, etc then you might not see the eye-brows on the pistons, but it'll be tight enough clearance that most would agree you should flycut!
Even at the 110º ICL I wouldn't run it without reliefs!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
