Forged internals
Forged internals
Maybe this is the wrong spot to post this but here goes nothing:
I am still learning so Im wondering what are forged internals? Im thinking bout going turbo so I know I will need them and I just wanna see what they consist of and would like to know if anyone has any shops they recommend?
LS1Tech Premium Sponsor
Are you wanting to stay stock stroke, or go with a 4.0" stroke to make it a 383ci?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Which heads are you planning to run, and about how much is "extreme" HP you are planning on?
__________________
If you get into a head with about a 64cc chamber, then the Wiseco -11cc dish piston would do nicely! With the GM MLS gaskets you'll net about 9.3:1 static compression or so. They are the strong 2618 forging, come standard with coated skirts, and a steel top/napier 2nd ring set!
__________________
