Compression Ratio
Compression Ratio
I am currently running a compression ratio of ~11.3 with a stock head (64cc) and was wondering what the CR would be if used a head with a 62cc?
LS1Tech Premium Sponsor
If everything else stays the same, you should be about 11.6:1 static with that chamber change!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
