lq4 w/ milled l92s w/ LS6 cam PTV issues?
I may as well ask to see if anyone knows off hand? The heads were milled .030 and I'm running the LS3 MLS gasket and the cam is the 02-04 ls6 cam. (I know there are probably better cams for this set up but I had it on hand and I'm not doing the bottom end until next winter).
The specs on the cam are 204/219 .551/.548 117.5 lsa
Thanks
Thanks
