difficult decision choosing between cylinder heads
Well I had a set of ported 317 heads for my 6.0 turbo build. Long story short they are not going to be able to be used anymore. I was planning on larger valves and milled to 63 cc. I have a lq4 based engine with forged rotating assembly, -20cc pistons, forced induction cam arp studs for everything 83lb injectors and ls6 intake manifold. I have the patroit dual valve springs with titanium locks and retainers and yella terra rockers. I have not yet measured pushtrod necessity length as I was waiting to get back the heads. I am trying to decide if I should order a ls3 head and intake setup or just go with an aftermarket ls1 style head. Will the rockers, valve springs, arp head studs, and injectors along with fast fuel rails bolt up the same to the ls3 intake and head setup also I have the bbk 88? Mm throttle body. I am not exactly sure on the size I am at work and don't have the papers infront of me. If it can all be used on an ls3 setup I will just go that route. If not I will have to look into a budget cylinder head as this project is quickly killing my bank account. I plan on running 18-20 psi out of a 76mm turbo. Any input would be greatly appreciated.
