bent pushrod/misfire??
Hello.. my car is missing pretty hard in wot. I have tried to fix what I have been told could be the culprit. I.e. plugs / plug wires, exhaust leaks. I feel like I'm chasing a ghost trying to find where the misfire is coming from. Could a bent pushrod be causing me all of this grief? Is there a way to check without actually going in? Any advice is welcomed. Thanks
Do you have LT's? If so, that is most likely causeing the problem (codes) due to the relocation of the upstream O2 sensors to a location further downstream. You should be able to get those codes tuned out.
