Blown Motor. What are my replacement options?
Old 04-19-2011, 09:20 AM
MTBSully's Avatar
Default Blown Motor. What are my replacement options?
Just picked up a 98 ws6 formula with a spun rod bearing or thrown rod or something. Regardless, it seems more economical to replace the motor with an LQ4, LQ9 or a 5.3 or something than to rebuild. Question is, are these shortblocks a direct fit for the LS1? Will heads/intake and everything else bolt right up? What about the PCM? Thanks for any and all input
Old 04-19-2011, 10:36 AM
mark21742's Avatar
Lq4 or lq9 can be picked up for pretty cheap. If you want to throw some money in it get a 4" crank, rods and pistons. Everything bolts right up other than the alt bracket on the iron blocks you need to drill and tap a hole in the front drivers side of the block, or like I did, just leave that bolt out (GTO alt brackets might be a hair different than the F-bodies)
Old 04-19-2011, 11:34 AM
PREDATOR-Z's Avatar
Yes they are pretty much direct bolt in, keep in mind that by changing cubes, you'll have to change tune.
So it might be the same just to get a GM LS1 (Check SDPC)
