Patriot stage 2 LS6 heads and Raptor cam????
How much power will i get out of a stock bottom end LS1 with, Mid-Length Headers, LS6 intake, 30# injectors, Patriot Stage 2.5 LS6 Heads, and a Raptor Cam, Vig 3600 stall, 3.42 gears?
And will I have to flycut my pistons to use that big of a cam? I had a 2000 camaro with the T-Rex and i was told i had to flycut my piston to use worked heads.
Are you heads milled? How much?
Do you have a thiner head gasket?
With stock heads and gasket, that cam will definitly fit in without pistons flycut and I guess your power will be close to 390 - 400 rwhp with good tune.
