Messed up EVERY valve during cam swap...
So I did my cam swap about a month ago. Within maybe 15 mins of having it running, I was burning a LOT of oil. I put maybe 50 miles on the car and decided to do a compression check. I was at 175-185 on all 8. All the plugs were fouled from burning so much oil. So today I decided to tear it down to check out the valve seals. When I got the first spring out, I realized the culprit... massive scars in the valve stems. Scars that are actually CUT into the stem. The seals were no match. I got to looking at the valve spring compressor that I got off here (Tim's Tool) and it seems that it doesn't line up right. It never did seem to work that well, but it was getting the job done so I never thought to investigate further. Here is a pic:
Is that the way it's supposed to look and install on the retainer? I would assume with 39 pages of good feedback and hundreds of positive reviews that the tool would have been made properly. When I compress the spring, it pivots in a way that scrapes the valve stem. With 150psi in the cylinders holding the valve up, Im assuming it wasn't enough to open the valve, so I never noticed this until now. So now the heads have to come off, which means new seals, bolts, gaskets, etc. In my opinion, either the tool is poorly designed or I got a lemon. I have used probably 10 different spring compressors before and never had a problem with any of them. (My compressor from Thunder Racing was lost in a fire this past winter.) To sum it up, should I be pissed or am I missing something? Any input is appreciated!
Its definitely not a valve guide issue. The way the compressor sits it's VERY hard to line up everything and, like I said, doesn't seem to "pivot" right. The damage was caused on every valve the exact same way and it's because of the way the spring is being compressed.
The seat is fine. The retainer is fine. The tip of the stem is fine. I don't have any pics of the actual damage, but something is not right. The valve stem itself right where it would be sliding through the valve seal at max lift (about 6/10ths of an inch above the seal when the valve is closed) is what's messed up.
First, the tool plate is on upside down, and second, I have used a Tims about a dozen times and it has been great. Be careful bashing a tool that you don't even know how to use....You won't be dragging the Tim's tool through the mud unless you have some solid proof.
I am actually against the idea of his tool's poor design and am leaning towards it being a lemon, which is why I am ASKING FOR HELP. So feel free to take off your asshat and put forth some input that will actually HELP instead of stating the obvious. Thanks!
Can anybody that has one in their possession install the tool and see if it aligns the way mine does and post a pic? To me it seems that the elongated hole for the stud needs to be another 1/4" higher to allow the part of the tool to fit on the retainer in a better manner. Any ideas?
You asked if there was something wrong. I pointed out there was. The tool is hitting the spring retainer fine. If it damaged anything it was user error. I don't know how much clearer I can possibly be about this. And on that note, there is nothing further to discuss here.
