dropped nut in cylinder !! engine died !!
This is what happened ,
an unnoticed dropped nut was in the cylinder. Cranked it up !! and this is what happened
there is a crack in the block . can that be fixed by some how ?
We are thinking about ls3/ls7 swap now.
there is a l92 6.2L almost indentical to a ls3 i think he is asking 3200 obo
https://ls1tech.com/forums/parts-cla...ete-motor.html
thanks , i'll check it
LOL .
i would just use your crank and what ever else you can and build a 6.0 like this,, brand new 850 bucks
http://paceperformance.com/i-6255354...ron-block.html
or you can buy a new ls3 for about 1300 if you look hard enough
I didn't know there was a nut inside the cylinder , until this happened.
LSX Mechanic
If it's just the sleeve, it can be fixed. However, it's probably going to be cheaper and less hassle to find another LS1 pull-out and install it.
Also, the LS3 engines have a different reluctor wheel on the crank. It's not exactly a "drop in" swap without changing reluctor or converting to an E38 PCM.
reluctor wheels are pretty easy to change. A little heat and they come right off. Throw the replacement wheel in the oven at 350 degrees for a half hour or so and it will slip right on.
LSX Mechanic
I realize how easy they are to change. I swap over 10-15 reluctors a month.
The internet is always quick to yell out extreme recommendations. "Hey it's blown up, throw a 427 in it!!"....
He doesn't need an LS3 and I'm sure if the OP had intentions of spending a bunch of money on another engine he would have specified so. The fact is, this fix can either be done by re-sleeving or another pull out shortblock. Simple, effective, cheap. An LS3 is an awesome swap to do, but right now while that engine still holds a pretty high value, it's anything but cheap (unless you get lucky).
Yea we are not thinking about fixing that , but I wonder how it can be fixed ? I mean what exactly they do to fix it ?
ok , do I install the ls1 reluctor wheel or another ? how do I know which one will fit ?
noob on this
