oil pump question and rod bolts
Old 06-14-2011, 09:41 PM
formerly twolow02fransen (2014-1-2)
02_Orange_D1SC's Avatar
Default oil pump question and rod bolts
well im building a LQ4 for my truck the motor is a brand new gm crate motor. im just wondering if the stock oil pump will be fine or if i should do a ported ls6 unit.
also should i do a set of ARP rod bolts or a set of KATECH ones from what ive read the ARP ones are longer and weigh alittle more then the stock ones so you should have the rods taken to a machine shop if you run the ARP bolts. or should i even bother with the rod bolts.
Old 06-14-2011, 10:19 PM
Exeodus's Avatar
Unless you plan on spinning your motor past 6000 rpm frequently, I think the stock rod bolts will be fine.
94mustang's Avatar
If you change the rod bolts, the rods need to be taken to a machine shop to check if they are still round. Chances are they won't be.
Old 06-14-2011, 10:20 PM
94mustang's Avatar
Rock the stock ones, you'll be fine
Old 06-14-2011, 10:51 PM
chrisfrost's Avatar
The newer rod bolts shafts are larger diameter than previous 1's and they're a kind of an ARP wavelock copy and would be good to at least 450whp . The main issue is what RPM's are You planning on reving to . Stocker bolts are good safely to 6300 day in and day out . The ARP sportsman bolts weigh 2 grams more each bolt than earlier GM rod bolts . I believe the later GM bolts weigh pretty close to the same as ARP's sportsman bolts .
Old 06-14-2011, 11:27 PM
i do plan on spinning it to 6500 to 6600
Old 06-16-2011, 10:08 PM
fastsspr's Avatar
I going to spin my motor like you and i already ordered my arp pro-series bolts.
My body used those in his Ls2 vette procharged 575hp 580tq on a mustang dyno and just put them straight up with now machine work and all.Still running perfect after 1 year.
So just going to bolt up them with machine work.
