5.3 stg. 2 heads vs 5.7 stg 2 heads .. How much more power ??
LSX Mechanic
Originally Posted by jrp
5.3's will make more due to the higher compression. how much more probably depends on the setup.
josh
Originally Posted by Damian
Thats about the jist of it. 5.3's carry a compression advantage over the 5.7 head due to the smaller chambers, but otherwise flow characteristics are nearly identical...The power increase will come from compression..
josh
josh
Now I need to know if my G5X-2 cam and the 5.3's work well together?
