Overheat help asap
Old 07-06-2011, 09:49 PM
mikemunoz's Avatar
Default Overheat help asap
Ok just got my motor back together and the water pump took a ****, i put a new one and it does the same thing, turn car on the car warms up for a while drive it around then it just start to heat up i turn the car off and open the hood, it shot out the water from the reserve tank and then i here like a click sound coming from the radiator what can it been, it is missing one water pump bolt. Can that be it
Old 07-06-2011, 10:31 PM
bravo863's Avatar
Did you get all the air out of the system?
Old 07-06-2011, 10:49 PM
SOMbitch's Avatar
Put the front end on a ramp and squeeze the hoses and burp it. You will need a rag or gloves as the hoses get hot....
Old 07-06-2011, 11:28 PM
mikemunoz's Avatar
so i just lift the front end of the car, i turn it on and keep putting water in it and squeeze the hoes in front of the water pump, till when how will u know if all the air is out, also can a overheating car cause oil pressure to drop
Old 07-06-2011, 11:49 PM
garygnu's Avatar
oil press drop mite be aq bad O-ring on the oil pump.do like SB said.
Old 07-07-2011, 12:32 AM
SOMbitch's Avatar
OP drop may also be oil heating up and thinning out. Yes I put mine on a ramp and squeeze the upper rad hose. You will see the radiator coolant drop and just add more til it quits taking it. Go for a ride and check again. Some people take the steam tube off the motor but I have never had to do that...
