which injectors should i go with my lq9
hey i hav a lq9 motor in my f body that i jus put in and my question is which pound of injectors should i go with this motor with my touqer v 3 cam?i want to spray at least a 150 shot on this motor any thing will help thanks.
150 wet or dry? For a wet shot I would say some 36 pounders. You could get some stock ones rejetted to 36, or run an SVO 30 which flows about 36 at our pressure. If you mean 150 dry shot, I would think 42 would be minimum. You will run those about 65% duty cycle NA so they will have room for a shot on top. SVO 42 green tops flow about 48 at our pressure so that would be good option as well. FIC injector can hook you up with rejetted stock injectors.
