How to get a 6.0 to 500 rwhp NA without a stroker.....
I have a 6.0 with untouched 317 heads, ls6 intake, 90mm throttle body, custom grind pat g cam, long tubes, and a 6 spd, behind a moser. I have made 440/417 is my best run. Car runs excellent for what minor mods it has. I want to push the envelope on my 6.0, So I was going to do LS3 heads, a fast 102r, 1 7/8 long tubes, and a 102mm tb, and have another custom grind cam done.
So my question is, who has come close to making 500 rwhp, out of an NA 6.0
If you haven't yet, see these 2 links for Patrick G's 347 build that eclipsed 500rwhp. He did it 4yrs ago with Mamofied AFR 205's, ported FAST 90, 11.9:1, and a cam similar to a Magic Stick 3. Now there's the FAST 102 and with your 6.0, it'll be even easier. The real kicker here is that this type of combo will be more driveable on the street than most 450rwhp h/c combos running hogged out OEM castings with a big cam.
https://ls1tech.com/forums/generatio...heads-cam.html
This is a snapshot of all the details.
http://guerragroup.com/2000TA.htm
Jason
Jason
LS1 Tech Administrator
I would not recommend L92 heads if you have your heart set on 500rwhp. The L92 heads are excellent, but they have a hard time getting to 500rwhp with a 6.0L. Reason? The huge 2.165" intake valves are very close to the combustion chamber wall and cylinder bore which really hurts power. You don't see this shrouding hurt it as much on the flow bench as it does the dyno (and track).
There are dozens of 6.0Ls that have made over 500rwhp with a quality cathedral port head like an AFR 230V2, PRC 227, TFS 225, or MAST 225. These coupled with a ported FAST 102 and a cam in the upper 230s will do a good job in getting you there.
There are hardly no 6.0L combos spitting out over 500rwhp, even with flycutting, higher compression, running stock or ported L92/LS3 heads. Valve shrouding is a killer. If you can be happy with 460-470rwhp, then the L92/LS3 heads work great when cammed correctly in a 6.0L.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
I was hoping for 500 with the l92's, but If I can do it with a set of trick flor or afr's I will. I am making 440rwhp right now with one of your cams, and untouched 317's through a 9inch so the 460-470 hp is not worth even swapping over. Guess it is time for me to save up alittle more. I have 2200 saved right now.
Besides price point and maybe a different rocker setup or longer pushrod (which basically boils down to price point), what are any drawbacks of an aftermarket head vs a stock head?
I thought the 317s and 243s had nearly identical flow in stock form?? The big difference was the combustion chamber size???
Guides - the service life of bronze guides is a fraction of the typical OEM guide
Components - the OEM parts are typically much lighter
Fitment - nothing has a higher probability of simply bolting back together & working well than OEM parts
Value - Same or higher output, longer service life, lighter parts, guaranteed fitment, and at much lower cost makes the CNC'd GM head a no brainer
The main trouble people get into is picking a hp # they think they must have. If performance is the goal, they need to stop the "I gotta have 500rwhp, 485 will be dissapointing" madness. Rarely does the car with the highest dyno # run the best. The entire setup needs to cater to the application - if the area under the curve needs to be focused such that we trade a few high rpm #'s for something in the lower rpm range, then so be it. That is, if your goal is performance potential designed around how you actually use the car vs. dyno racing. The latter is focused on because it is easy. There is no shortage of ways to make a dyno sheet with whatever # you like, if that is the vehicle's sole purpose.
I do not recall what the 317's flow in stock form - that isn't something we really take into consideration. Physically we can cut the 243 programs in the 317's, and as mentioned we can simply alleviate the only drawback of the 317 (ls1 style chamber) and correct it to 243 or better characteristics.
I third this..
Ahhem..
Granted this is an 04, but still. He's NOT far off! Very impressive numbers for a "modest dyno."
https://ls1tech.com/forums/dynamomet...lt-04-gto.html
Ahhem..
Weight - many add 15-30lb to the nose of the car above CG
I am curious to see a 243 head match up against a trick flow in as cast form, or in cnc'd form. When both have their magic worked on them. And I am glad that the darts I had had bronze guides instead of the iron ones. If they were iron and the valve bent, it would have cracked the head. Instead the bronze just deformed and a small piece is missing where the valve stretched it out.
The points always favor which side you scrutinize and specialize in i guess.
As far as weight, the thicker deck is there for a reason. Can you say that an aftermarket head has had as many reported problems of warping/pushing water than the LS3 heads under boost? How much more durable is a stock head then than an aftermarket. Esp when you redesign the chamber and make that portion of the head even thinner? And mill them.
