ls1 bottom end ?s
ls1 bottom end ?s
what order should the main caps go #1 in the front to #5 in back correct? how do the rod ends mount on the crank need pics motors been apart so long so i dk anymore. An whats the ring gap on a stock ls1 346. i also have this lil black metal clip that mounts on the block somewhere an it bolts in with a 10mm
Main cap order:
https://ls1tech.com/forums/7646966-post2.html
Ring gaps:
https://ls1tech.com/forums/12785510-post4.html
Ring gaps:
