F**K! Broke an oil pan bolt
Old 03-01-2003, 11:24 AM
pekkaz's Avatar
Default F**K! Broke an oil pan bolt
I was torquing oil pan bolts back and didn't notice the rear bolts spec is much less.
Is there any chance it will hold without the bolt ?
Old 03-01-2003, 11:25 AM
SAINT WS6's Avatar
Default Re: F**K! Broke an oil pan bolt
It would probably hold, but I wouldn't trust it. Better safe than sorry.
Old 03-01-2003, 01:22 PM
SLowETz's Avatar
Whoops.......
I too was a victim of the broken "oil pan bolt" syndrome. That bolt is not an oil pan bolt per say in that it threads into the rear cover at 106" lbs., not 18 ft.lbs. Some folks just leave it and hope for the best.
I nutted up and dropped the trans, and fixed it proper. The bolt is there for a reason......
Do a search on "oil pan bolt" and have a look.
Old 03-01-2003, 03:42 PM
2001CamaroGuy's Avatar
Is this the long bolt that comes from the bottom or the short that comes from the rear (through the bell housing)?
If it’s the long bolt, join the club. It’s a torque-to-yield bolt so once it’s been used; you need to get rid of it. I broke one off when I did my head/cam swap. You can drive around without it but you should really drop the pan, pull the broken piece out, and get a new bolt. Most likely it broke above the surface of the block so you will be able to just back it right out (won't need to drill).
If its the big short bolt coming through the bell housing, BY ALL MEANS FIX IT! That holds the bell housing to the block and takes a lot of abuse.
Chris
Old 03-02-2003, 12:34 AM
pekkaz's Avatar
Hmm, I guess I'll try without it first. The engine is in the car and would probably have to be lifted to get to the threads and bolt remains.
Old 03-02-2003, 09:16 AM
pekkaz's Avatar
Thanks guys, it's the long thin bolt. I'll try to hang on until late spring when I'm pulling the tranny.
Quick Reply: F**K! Broke an oil pan bolt
