LG G5x2 cam owners what pushrods
Old 09-03-2011, 07:31 AM
MonmouthCtyLS7's Avatar
Default LG G5x2 cam owners what pushrods
are you running ...its on a 114 LA.....probably be mateing it up with some ported 243's
Old 09-03-2011, 08:33 AM
brett walker's Avatar
Comp 7.4s in mine
Old 09-03-2011, 10:34 AM
Nice, thx man
Old 09-03-2011, 04:34 PM
PREDATOR-Z's Avatar
measure
Old 09-03-2011, 04:41 PM
mred's Avatar
Originally Posted by PREDATOR-Z
measure
right..
its a new concept
Old 09-03-2011, 04:45 PM
02blackbeauty19's Avatar
measure
Beat me to it.
Old 09-03-2011, 07:00 PM
mike c.'s Avatar
On a 112lob i was 7.4. The x2 is a great cam,i ran it. The x3 is even better. The x4 only gained me 5hp more on the dyno and no gain at the track.
Old 09-03-2011, 07:56 PM
Black 99 Bird's Avatar
Are you planning to mill the 243s?
Old 09-04-2011, 08:19 AM
Think im actually picking up some bowl blended 241s that im gonna have ported....and yes I know u should measure but im not doing the work
Old 09-04-2011, 09:24 AM
I bet, I grabbed it used for a good price plus I still need to stay emissions compliant
Old 09-04-2011, 12:44 PM
LSX Mechanic
Damian's Avatar
The amount if misinformation being thrown around this section these days is enough to give me an f'ing migraine headache.
Let me explain something to the rookies. And I'm gonna bold it, so hopefully I can get my point across.....
An aftermarket camshaft will have anywhere from .030-.060 shaved off the base circle to allow large lobes to pass cam bearings. This will create a need for more travel, therefor calling for a longer pushrod. No how, no way, will an XE-R camshaft of this size have proper valvetrain geometry with a stock length pushrod. The internet mechanics are wrong.
That being said, all the LG cams I've installed called for a 7.450 pushrod with a stock unmilled GM gasting.
Old 09-04-2011, 02:35 PM
Ty sir
Old 09-04-2011, 07:20 PM
2slow2flurry-ous's Avatar
Another ls1 saved. Good work buddy, now go contemplate how awesome you are lol.
Old 09-05-2011, 03:54 AM
PREDATOR-Z's Avatar
Mind you he did not recommend 7.450, he said that is what he used on a few swaps.
The bottom line, Damian is correct, internet is not the place to chose you p-rods.
That should be done under your hood in your engine bay. MEASURE
There is no sure way around it.
When you go to the bathroom and ****, first you have to grab your Shlong. Failing to do so can be most of the times MESSY. The same applies to push rods, MEASURE for correct p-rod length and lifter pre-load.
(Now repeat the above until set in your conscious)
Old 09-05-2011, 07:49 AM
Alrighty Predator im a little confused....and granted im not mechanic BY ANY MEANS, the most complex thing I ever did was install my converter w/ a buddy in which he did 75% of the work and it was a friggin nightmare for me...I just don't have the patience but Damian said on non milled factory head those were the pushrods he used w/ this cam so what would make any measurement different from the next on the same motor...Not being an *** i honestly just don't understand
Old 09-05-2011, 01:22 PM
mike c.'s Avatar
emissions can cause an issue. no matter,the x2 was a nice performer and will do its job for ya. goodluck with your build.
Old 09-05-2011, 05:41 PM
PREDATOR-Z's Avatar
Because every motor is different. Measuring takes any guesses or issues out; and when someone asks you "What is your preload?"
You confidently reply .xxx
Old 09-05-2011, 06:55 PM
Thanks.......
Old 09-06-2011, 12:10 AM
LSX Mechanic
Damian's Avatar
Predator is right, measuring is the only way. Especially if you're a first-timer or only do this occasionally.
I've probably installed 150-200 XE-R lobe camshafts since the XE-R lobe came out. I'd like to think at this point I've got a pretty good feel for what pushrod they call for on a stock unmilled head, with a stock LS1/6 lifter which is typically a 7.450. On a rare occasion they'll want a 7.425.
I guess for me it's safe to assume pushrod length now, since I'm typically right on the money and regardless I measure anyway. If I've ordered the wrong length, I just get on the phone and order the right one. For the DIY'er, pushrods are the absolute last thing that need to be ordered. Once the cam swap is buttoned up, length needs to be measured. Then you can order your correct length pushrod.
But I'll say it one more time. Never, will an XE-R cam have good geometry with a 7.4 pushrod. Just because "it'll be fine" doesn't make it right. There's a lot of things that an engine will let you get away with temporarily, but you'll pay for it in the long wrong.
Old 09-06-2011, 08:50 AM
Great info thx guys
Quick Reply: LG G5x2 cam owners what pushrods
