possible cam tell me what you think
i have a 95k mile 02 ls1 just wondering if this is a good set up, im also going to get some 243/799 heads to throw on suggestions welcomed.
Texas Speed Camshaft Package w/ Dual Valve Spring Kit
SKU: 25-CamPkg2 Change This Kit
- Texas Speed 233/239 Camshaft (112 LSA)
- PRC .650" Dual Spring Kit
- 7.400"
$699.99
GM Replacement LS7 Lifters
SKU: 28-12499225 $139.99
N Motion LS2 Single-Roller Timing Set
SKU: 103-SD7240 $89.99
Melling High Volume Oil Pump
SKU: 122-MEL10296 $159.99
Sub Total: $1,089.96
- 7.400"
$699.99
i figured replacing all that stuff would make it last long enough for me to build my 390 or 408. dont really wanna drop motor out to replace rod bolts or anything. ill probably just keep it set for 6500 rpm. i mean motor is strong just sounds like a dam diesel when i first start it.
yes on the n20 and going to the track pretty frequently, i found some 799 heads just wondering if it would be worth doing this over the winter or just wait and get a AES 390 built for a d1sc.
that was the converter Jake's converter guy suggested for what i had at the time, i do plan on a different one tho once i go fi i can use the 3200 with a 100 shot for now if i do h/c.
