white smoke coming from my tail pipes
Old 10-11-2011, 11:53 PM
millie200's Avatar
Default white smoke coming from my tail pipes
white smoke coming from tail pipes when its idle and its missfiring
need some help any one?
Old 10-12-2011, 05:11 AM
KRAZY K 2000 TA's Avatar
check and see if you have water in oil, then pull the radiator cap and see if everything looks okay in there, if they are okay have the radiator pressurized and see if it holds pressure.
Old 10-12-2011, 06:39 AM
AlamoTA's Avatar
Time to do a compression check to try and isolate where the water is being introduced to the combustion chamber. It's usually a sign of a cracked head, blown head gasket, or cracked cylinder wall
Old 10-12-2011, 01:56 PM
millie200's Avatar
well i check my oil and it have no water in it but i never had my radiator pressurized yet and its missfiring really bad when idle so do u think is my rings or what ?
Old 10-12-2011, 02:00 PM
millie200's Avatar
but my car its not running hot if its was i blown head or gasket wont it run hot ???
Old 10-12-2011, 08:05 PM
LilJayV10's Avatar
Yes it can but it will start running hot eventually. It depends on how the gasket is blown. Do a compression test and find out what cylinder/s it is.
If it's misfiring you will probably be able to tell when you pull the spark plugs out.
Quick Reply: white smoke coming from my tail pipes
