Where can i get single Mahley pistons
hi i'm wondering where i can get single mahle pistons
i need 3 mahley ls1340898f04 pistons and a set of 8 rings
thanks
Baezi
thanks
Baezi
Well you can call Summit or Jegs and give them that part number and they will ship it to you. I am sure there is a sponsor on here as well that could do the same. However you need to make absolutely sure that you have the right part number. I just bought a set of mahle LQ9 +.005" bore, 3.622" stroke, 6.098" rod, with a .927" pin that was spec'd to me by someone else. The pin in a LQ9 is .943" or so. So make sure you have exactly what your engine requires with that part number.
