What is your oil pressure???
Old 10-23-2011, 09:35 PM
Nashty's Avatar
Default What is your oil pressure???
I'm working on a project and need some help with what people's typical oil pressures are.
I have a washer behind the spring and see over 70psi at full boogie and probably around 30 at idle. Seems kinda high so I want to know what pressures are typical for most people.
So if you don't mind:
Hot idle / Hot WOT
Thanks,
Roger
Old 10-23-2011, 09:47 PM
turbo iroc's Avatar
50 cold idle, 30 warm idle, about 60 at wot. Stock pump from a 70k mile lq9.
Old 10-23-2011, 10:07 PM
Whiteaw57's Avatar
45-50 Cold Idle/35 hot Idle 170*/70 at 6000 rpm Hot
Old 10-24-2011, 05:29 AM
VandykeT/A's Avatar
Cold start 75 sometimes I think its gonnna completely peg and on a cool day about 60 hot idle but on a really day I've seen around 50ish. Thats a TSP ported pump.
Old 10-24-2011, 08:06 AM
1CAMWNDR's Avatar
Meling high volume/pressure pump. 60psi at idle, between 60 and 75psi WOT. It never goes to the 40psi mark.
Old 10-24-2011, 10:45 AM
O2Form's Avatar
Stock 02 65psi cold idle 45 hot idle 70 wot hot
Old 10-24-2011, 11:36 AM
Old School Heavy
speedtigger's Avatar
30-35 idle & 70-75 high rpm with melling pump
Old 10-24-2011, 11:41 AM
s346k's Avatar
99 ta with 100k miles, stock everything. mobil 1 5w30 synthetic. 30psi hot (200*) idle 60psi hot wot 5500+ rpm.
something odd i've noticed is that it goes from 30psi up to 40psi @ 1200 rpm and only makes 40psi until 4k or so. then goes up to 60 on the nose around 5500.
Old 10-24-2011, 11:54 AM
bjamick's Avatar
Usually a little over 60 cold start and stays there when warm and nearly pegs the gauge under WOT.
Old 10-24-2011, 11:56 AM
DarkFox118's Avatar
just over 40 idle, just over 40 driving, just over 40 cold start.
I wonder if my gauge is working?
I rarely take the car wot and when I do, I'm not looking at the oil pressure gauge, but the object/situation that made me go wot. From what I recall though, it was up around 50 when I was paying very close attention to this, but that was back during mid summer, 90 degeree days.
totally stock, worn out LS1, barely alive btw.
Old 10-24-2011, 12:04 PM
SSCamaro99_3's Avatar
60 psi cold idle, 42 psi hot idle, over 60 psi as rpm climbs.
Old 10-24-2011, 12:14 PM
ZeeOSix's Avatar
Stock LS6 in 2002 Z06. Hot oil (200 ~ 210 deg F), Mobil 1 5W-30 full synthetic.
Idle (800 RPM) = 32 ~ 33 psi
WOT (5000 RPM) = 65 ~ 68 psi
Old 10-24-2011, 02:52 PM
ZexGX's Avatar
Forged 347 w/SLP oil pump & Mobil 1 10w30 Extended Performance. Total Seal brand moly coated rings:
Cold:
Idle = 50-60psi
WOT = I don't go WOT when the motor is cold...
Mostly warm oil:
Idle = ~40psi
WOT = ~55-~65+
See below for hot oil pressure (68+ at WOT):
Old 10-25-2011, 07:49 AM
Steve Gunn's Avatar
The in car video in my sig shows various rpm pressures. It's a ported, shimmed stocker.
Quick Reply: What is your oil pressure???
