Best bang for your buck LongBlock !
Old 12-08-2011, 08:50 PM
973800CamaroRS's Avatar
Default Best bang for your buck LongBlock !
Hey guys I have had my mind set on a lq4 370ci build but I have been looking around and am starting to wonder if there are better options. For starters This engine will be replacing the 355 in my 70 Camaro. So I have a few options for you guys to critique. This is going to be a mainly street car that I want to be very reliable but also make good power !
Option 1: Make a 383 out of current 355
Option 2: Same as option one but run a vortech supercharger. (blow Thru)
Option 3 : Lq4 370ci build
Option 4: LSX 376 (This has really sparked my interest, a lsx long block for 5400 bucks)
Option 5: What is your guys suggestion my budget is about 8000 for everything.
Old 12-09-2011, 10:43 AM
LS1-450's Avatar
Came in here a few hrs. ago & left thinking too much to consider. Then, thought about it & ...
Could build a strong LS2 6.0L that makes 600 BHP for 5K or less including the long tube headers you'll need, intake, TB, PCM; etc.. With the right home head porting, the right cam & all the other little power saver mods., could be done. IMO, why spend 8K when you could build a similar power plant for under 5K?
However, if you're committed to the 376, then I suppose there's more power to be had + the added expense of block work & more expensive pistons or the $5400 long block + long tube headers, intake; etc.
Personally, I'd eliminate options 1 & 2. Unless, gas mileage is of importance. In that case option 2 through LS1 cubes might be attractive.
Old 12-09-2011, 10:58 AM
01ssreda4's Avatar
$8k budget but the car isn't set up for a Gen 3 engine? I'm assuming the 355 is a Gen 1?
Old 12-09-2011, 02:06 PM
Yea the car is set up for a gen one but I will be swapping a engine in soon.
The reason I am saying 8k is because If you figure say $5000 for the long block that gives you $3000 to spend not that much considering you need. Intake, Oil pan, injectors, ecu, wiring harness, headers, etc. You would be at or above $8000.
Gas mileage is not important if i get 10mpgs I will be happy. I mean each engine you pay for what you get but in different areas.
Old 12-09-2011, 04:35 PM
01ssreda4's Avatar
I'd buy a complete 6.0 pullout. There is your wiring and PCM too. Price would likely be $1k-1500. I'd do something simple like a set of TSPs CNC'd LS6 heads for $1500, or pull the 317s off the 6.0 and send them to A.I for 1k. Pick a nice cam to match your goals with valve springs and pushrods should be about $750. There is your long block for less then $5k and it should make great power.......
Pullout engine 1500
A.I. CNC........1000
Cam stuff.......750
.....................3250
Unless you were wanting a brand new engine?
Old 12-09-2011, 05:24 PM
ssred : Yeah that's what I have been thinking that was my 370 lq4 plan but even with what you said I would replace the intake and front drive accessorys plus machine work. That would get me to the 450whp level I'm looking for. I want the peace of mind while the engine is spinning 6500rpms that everything inside is built.
Old 12-09-2011, 05:42 PM
redbird555's Avatar
450whp out of a stock ls type engine is plenty reliable. The inside will hold up fine at that power level, I'd do what ssred suggested and get a pullout 6.0 then add some decent heads, whether you go aftermarket or just ported stockers then select a good cam and intake. that will either meet or exceed your power expectations. In addition to what was suggested for peace of mind i would throw in a set of rod bolts whether you go arps and get the rods resized or just swap in katechs, that will ensure that you can spin to 6800 all day long with no problems.
Old 12-09-2011, 05:43 PM
LS1-450's Avatar
Must have been talking to myself...
Old 12-09-2011, 05:50 PM
Ls1-450 Your right I haven't thought about that but wouldn't a lq4 be cheaper ? for the same cubes. I know its an aluminum block but still.
Old 12-09-2011, 06:10 PM
Doug G's Avatar
I'm pretty much in the same boat as you are....but I have a 406ci SBC (old school motor) and it has performed great over the years...but times and wants have changed
I have my name on a LQ4 motor (needs a rebuild...but could be just a hone and bearings ?)
After seeing what these LS motors can do and how easy it is first hand.... GO LS
Old 12-09-2011, 06:20 PM
Thanks man and yea I agree you cant compare a old engine to a new fuel injected one just not the same. The only thing is people are starting to catch on and used ls engines are getting hard to find for a good price.
Old 12-09-2011, 07:09 PM
~ReapeR~'s Avatar
You could also do a turbo 5.3.
Friend of mine who actually swayed me to put my 5.3 in after the ls blew has a early 80s Malibu wagon with a turbo 5.3 pushing around 500+.
Just a suggestion. Would be the best use of the money.
Old 12-09-2011, 07:12 PM
So many options haha. But I think I am going to stick naturally aspirated. Just want a bada** street car.
Old 12-09-2011, 08:28 PM
SWEET98SS's Avatar
Did you check out thompson motorsports a sponsor on here, they have some great specials going on now.
Old 12-09-2011, 08:54 PM
gs462's Avatar
http://www.texas-speed.com/p-593-tsp...ort-block.aspx
http://www.texas-speed.com/p-588-tsp...ort-block.aspx
Old 12-09-2011, 09:28 PM
That's MISTER MODERATOR
Paul Bell's Avatar
I'll second for the pullout 6.0. You'll have enough money left over to do a decent bottom end re-build including a nice forged rotating assembly with forged slugs. Plus, it's an aluminum block so there's a decent weight savings which would greatly benefit a long nosed second gen F-Body. And the folks at AI know what they're doing.
Old 12-09-2011, 09:30 PM
Yea I know of TSP I would love to buy one of their 408 longblocks but it would be over my budget of $8000. With intake and fuel injection etc.
http://www.texas-speed.com/p-655-tsp...ong-block.aspx
Old 12-09-2011, 09:34 PM
In my opinion I would rather do a Lq4/9 Instead of an ls2 because of the saving I could buy the intake I will need with the savings.
Old 12-09-2011, 10:33 PM
01ssreda4's Avatar
Iron block is gonna be tons cheaper then an aluminum block because they are much more abundant. I do not think you need a rebuild for a H/C NA motor if the donor engine is healthy. I'd say maybe do rod bolts and roll. With your goals, you won't be stressing a stock bottom end much at all IMO. Rebuilding it right off the bat is pissing money away.
Old 12-10-2011, 09:38 AM
s346k's Avatar
i agree with this 100%. these motors are very strong and you won't find the limit of a stock bottom end anywhere near 450 whp.
i second the rod bolt suggestion. a 6 liter should have no problem finding 450whp under 7k rpm. it's all in the parts combo and tune. whatever is done, source a good tuner. otherwise, your money would be better served as bedding in a horsebarn.
Quick Reply: Best bang for your buck LongBlock !
