Where to get heliCoil kits online? Size & lenght of Rocker bolt?
Whats a good place to order a helicoil kit? I need it for the rocker bolt hole i crossthreaded (last resort plan if nothing else works). I believe the bolt is 8mmX1.25...is this correct?
Thanks for the tips. I used a tap on the threads since they werent too messed up. The first few were kinda rolled. I tapped it and it bites hard so I installed the rocker w/ locktite and torqued it to spec. No problems.
