MLS gasket??? reusable?? head bolted down for only two hours
Old 03-18-2004, 01:09 PM
KGSloan's Avatar
Default MLS gasket??? reusable?? head bolted down for only two hours
well, i goffed. nothing big, but here it is. got my heads from AS yesterday and started on the car today. the heads have a specific side since the intake is matched up to them. i was a moron and put the drivers side head on the passenger side and didn't realize it until i went to put on the drivers head . so, i pulled the head i had put on the passenger side and put the correct head on the passenger side with my other new gasket.
my question is, the head was only torqued down for a couple of hours and the gasket looks perfect. do i need to go get a new head gasket or is it ok? it's not a big deal to go get a new gasket, but if it's not needed then i won't bother.
thanks for you help
Old 03-18-2004, 01:11 PM
Nasty N8's Avatar
Yes you can reuse them its fine.
Nate
Old 03-18-2004, 02:20 PM
ROGERSPERF.'s Avatar
If it is a cometic yes it can be reused.
mike
Old 03-18-2004, 02:48 PM
smokinHawk's Avatar
defintatly YES you can
i have cometic gaskets (mls) and ARP studs, have took them on and off, many times.
they are made to be reusable.
Old 03-18-2004, 04:41 PM
bomax's Avatar
If you're using stock head bolts, they can't be reused, however.
Old 03-18-2004, 06:33 PM
KGSloan's Avatar
thanks for all the replies. especially nate for being so quick. i reused the gasket and bought some new head bolts. i have the heads all bolted up and will put on the intake and exhaust tomorow and be all fired up. i'm pretty damn excited. it's been a long time in the making
