PAC 1519 question
Old 02-13-2012, 06:44 PM
01SOMZ28's Avatar
Default PAC 1519 question
PAC1519:
- 1.290” Diameter Spring
- Nitrided Ovate Wire Spring
- 150# at 1.800” / 363# at 1.175”
- .650” Lift Capable
Would I be ok running these with my cam? Specs are 228/235 .614/.621
Old 02-14-2012, 12:18 AM
99Bluz28's Avatar
PAC only list the 1519s for .625" max lift.
The PAC 1518s are also listed for .625" max lift, but in the comments section of 2012 catalog it says for up to .650" lift. (scroll down to pg 12 of pdf 2012 catalog under "LS Engine")
http://racingsprings.com/Multimedia/...talog_2012.pdf
http://www.racingsprings.com/Beehive_LS_Springs/sku/171
After reading the 1519 specs it looks to me that they would be good for .040" more lift than the 1518s.
IMO, I'd contact PAC to verify what the max lift is.
Old 02-14-2012, 03:52 AM
01SOMZ28's Avatar
I just copied and pasted that from SpeedInc.
Old 02-14-2012, 04:02 AM
vettenuts's Avatar
Depends on the installed height. I found that the stock setup doesn't come in at 1.800" but closer to 1.765". Not sure what coil bind is on those springs but you should measure the installation height and proceed from there.
Quick Reply: PAC 1519 question
