cylinder head pressure test
Old 03-03-2012, 07:18 PM
3rdCoastPowerSports's Avatar
Default cylinder head pressure test
does a successfully passed cylinder head pressure test insure you that there will be no coolant leaking into the chamber or ports regardless of operating conditions?
Old 03-05-2012, 03:50 AM
chrisfrost's Avatar
I would say that it would depend on what pressure the cyl head was tested to . What is the normal pressure # to test cyl heads to ,,,,,,,,,,,,,,,,,,very good question ?
Old 03-05-2012, 10:20 AM
The shop I use tests them at 35psi. That's roughly 3 times normal operating pressure
Old 03-05-2012, 05:19 PM
chrisfrost's Avatar
For the most part that should ensure a positive seal with the exception of extremely extenuating circumstances (overheating at some point it will leak).
Old 03-05-2012, 05:51 PM
that's what i thought, i was just wondering about thermal expansion of the metal and its effect on opening up possible cracks
Quick Reply: cylinder head pressure test
