Valve Stem Seals
Old 03-06-2012, 12:39 PM
01FASTWS6's Avatar
Default Valve Stem Seals
So I purchased this valve spring kit
http://www.summitracing.com/parts/TFS-2500300/
and it came with 16 brown seals. even the parts list it came with say 16 brown seals. Just wondering if this is normal? I thought ususally there are two different colors.
Thanks in advance for the input!
Old 03-06-2012, 12:41 PM
97badass's Avatar
They are the same on exhaust and intake.
Old 03-06-2012, 12:43 PM
ZeeOSix's Avatar
That is a dual spring kit, which will come with its own guide seals because the OEM GM seals will not work with dual springs (only with single beehive springs).
Yes, the OEM valve guide seals are brown (EX) and black (IN), but doubt these aftermarket seals are the same way.
Old 03-06-2012, 12:55 PM
01FASTWS6's Avatar
Originally Posted by ZeeOSix
That is a dual spring kit, which will come with its own guide seal because the OEM GM seal will no work with dual springs (only with single beehive springs).
Thanks for the info, makes sense! Hopefully I'll finally have this thing running tonight!
Old 03-07-2012, 12:28 AM
01ssreda4's Avatar
Yep, z06 is correct.
Old 03-08-2012, 09:02 PM
McAllister513's Avatar
The valve seals that came with my TEA Dual Gold Spring kit came with all the same color seals. Just thought it was normal.
Old 03-08-2012, 09:09 PM
97badass's Avatar
I just got 16 new ones and mine are blue
Quick Reply: Valve Stem Seals
