Will the LS7 Oil System fit the LS6?
Does anyone know if the 07 Z06 LS7 Corvette dry sump oil system: oil pan, gasket, bolts, front cover, oil pump, pick-up tube, feed and return lines and oil pump drive gear will work on a 04 LS6? I'm considering a dry sump or Accusump. I happen to find the 07 LS7 dry sump for sale and considering options. Thanks, Jim
Found the answer. Just read it online in Super Chevy...."Here's a look at the special dry-sump oil pan. Because of the dry-sump system, there are two drain plugs, indicated by the cast-in line running between them. And before you ask, the answer is no: the LS7 pan--and corresponding dry sump system--will not bolt up to an LS1 or LS2 engine. There are too many differences with the front cover, crankshaft and other components.
Read more: http://www.superchevy.com/technical/...#ixzz1pLtu5GwV
