gaket and oring chart for a ls? IDENTIFY THIS O RING!
Does anyone know where a pdf file or even a web page is that has all the gaskets and o rings that a ls motor has?
Anyone know where this oring would go? This is on a 01+ Lq4 if it matters.
Here it is ontop of the oil pump orings so u can get a size diff
Here's a pic showing that its roughly 7/8 in diameter
The only place I see close at first glance is the oil pump pick up tube to oil pump o-ring but those are usually blue , red or green ,,,,,,,there are some o-rings in the TB like the idle air control solenoid valve or maybe the oil pressure sending unit or the cam sensor .
