Head bolts
Old 03-17-2012, 08:18 PM
cajunss's Avatar
Default Head bolts
About to do my head and cam swap and getting the last items I need. Wondering if I should buy just the GM head bolts or go with the ARP set. Are the ARP worth the extra $?
Old 03-17-2012, 08:31 PM
gMAG's Avatar
I think that the GM bolts will more than do. Inexpensive (comparatively speaking), does the job.
Old 03-17-2012, 08:41 PM
usafws6's Avatar
youll be fine with the gm bolts, arp is really unecessary if your not boosting or running high compression or rpm.
Old 03-17-2012, 09:14 PM
garygnu's Avatar
you can just torque the arps with a torque wrench.with stock gm head bolts (tty) you need a degree gauge also to get proper torque value.
Old 03-17-2012, 11:07 PM
badazz81z28's Avatar
The ARP head bolts are also re-usable. I have read that TTY bolts are better simply because the factors of friction etc can cause a not so accurate torque with traditional bolts. TTY bolts over come that. ARP is also twice the cost...
Old 03-18-2012, 12:58 AM
yonerhottlt1's Avatar
The ARP's are reusable. Worth it in my opinion
