5.3 Engine with 243 heads valves hitting block
Old 03-28-2012, 01:03 PM
TPIIROC's Avatar
Default 5.3 Engine with 243 heads valves hitting block
I was told by a machine shop that with 243 heads on a 5.3 the intake valve will hit the cylinder wall and that you need to clearance the cylinder wall. Anyone else heard of this.
Old 03-28-2012, 01:27 PM
Jeremy@RPMTransmissions's Avatar
Sounds like you need to find a new machine shop that is familiar with LS engines
But no this is not true. A lot of the new 5.3 engines come with 799 heads which are identical to the 243s.
Old 03-28-2012, 01:28 PM
TPIIROC's Avatar
It was TPIS that told me this.
Old 03-28-2012, 01:29 PM
It is unfortunite that they don't know this info. If you increase the valve size then you will have problems. But with the stock valve size you will be fine.
Old 03-28-2012, 01:33 PM
TPIIROC's Avatar
Completely stock heads
Old 03-28-2012, 02:51 PM
Troy5061's Avatar
The gen 4 5.3 trucks came with 243/799 heads stock, as did wifeys LS4 5.3 GP GXP, and a buddy is running 243s on his 5.3 turbo setup with no issues. Sounds like they are full of **** lol.
