.002 oversized an .010 undersized rod bearings. help!
Old 04-06-2012, 04:41 PM
Restricted User
kalebm22's Avatar
Default .002 oversized an .010 undersized rod bearings. help!
i had arp bolts installed and the rods were resized .002 and the crank was turned .010 so i am having a terrible time finding a part number for the bearings i need. if someone could please help me that would be awsome. i have searched but havnt come up with anything and the guys at summit were no help at all
Old 04-06-2012, 04:48 PM
KCS
Moderator
KCS's Avatar
Clevite 1776P-10
Old 04-07-2012, 10:54 AM
Restricted User
kalebm22's Avatar
ok thanks man i ordered the bearings, now i need to figure out how to get my compression ratio down for the blower. im going to have to run 806 heads sense the 317s i bought are cracked. so what compression ratio would the 806 give me on a stock 2007 6.0 block with a .051 gasket thickness? and how much would polishing the combustion chambers and running a .071 thick gasket help the compression ratio?
Old 04-07-2012, 11:56 AM
KCS
Moderator
KCS's Avatar
If your 6.0L has flat tops and the 806's have ~ 66cc chambers, you're still looking at about 10.8:1 compression.
If you had the 317's with 72cc chambers, you would be about 10.1:1.
Old 04-07-2012, 03:44 PM
Restricted User
kalebm22's Avatar
i have the dished pistons, the lq4 pisstons actually. i think the lq4 is 9.4 to 1 compression stock with 72cc chaambers. so i have been working my 806s over some and i am goin to cc the combustion chambers but i tthink i can get them to 68cc. then run the .071 thick headgaskets. i think thhis should get me back down to the 9.4 to 1 area. does that ssound about right?
Quick Reply: .002 oversized an .010 undersized rod bearings. help!
