do LQ9 rod bolts need to be upgraded?
Im about to do the swap in my 99 TA.. Trying to think of all the crap I should do when the motor is on the stand... suggestions?
So far, Ive got:
New front/rear cover seals
Oil pan gasket
Timing chain
What else can I do? I want to do the rod bolts with ARPs. I can just pull one bolt and replace it with the ARP? Then torque to spec, right? Seems like Im missing something...
So far, Ive got:
Oil pan gasket
Timing chain
On my first ls1 I used the Katech bolts, just like you said, take them out and replace them one at a time and never had a problem....the Katech bolts even held strong when I sucked a bunch of water in and blew number 7 rod out the side of the block lol.
I'm running ARP bolts in my engine now (had them resized) and working great.
So either way will work
