Few questions about a 383 build
Looking into a higher comp 383 build. Will likely use the 2.5 5.3 heads, and a decent size cam. I've heard a Ls6 intake won't flow enough, but what about a ls6 intake with a 90 snout? Also, what would need done for fuel? ( would just an injector swap deliver enough or would the pump need swapped)
It will see nitrous, but the nitrous fuel will come from a seperate stand alone cell with seperate pump
