Ls1 windage tray to lq4 with arp main studs question.
Old 05-06-2012, 07:17 PM
703 CAMAROSS's Avatar
Default Ls1 windage tray to lq4 with arp main studs question.
I was putting my ls1 windage tray on to my lq4 with arp main studs. The tray would not fit over the studs because there were 3 oval shapped holes on it. I drilled them out and made it fit. Now in one spot of the windage tray its touching one of the short studs after I tightened it down. It's barely touching. I think it will be ok but wanted others opinions. It's not like the stud ever moves. I'd like to get more opinions though.
Old 05-07-2012, 10:34 AM
mark21742's Avatar
You should be fine...as long as the rod ends or rod bolts don't hit it.
Old 05-07-2012, 11:36 AM
None of that was hitting. I rotated the engine just to check for that.
Quick Reply: Ls1 windage tray to lq4 with arp main studs question.
