eps 226 234 cam
eps 226 234 cam
about done putting this cam in my car. have any of you guys use this cam so far. if so how do you like it. appenely its a good cam for power all around the power range. does this cam make good low end power too. it seems to make power around 4 to 6 grand woud it be a good street car cam or should i look for somethin different. thanks for your guys help and opinions.
Old School Heavy
I have the EPS 226/234 with 110LSA. In my car it runs better on a 108 ICL than on 110. It is a strong cam. Power everywhere from 3000 to 6500 in my car. My car will go 11.40s at 3700+ lbs with a small 2800 converter. If I were to do it over, I would probably go with a 230/234, but my car is a toy not a daily driver.
My car is a street car. How is the power from 1000rpm to 3000rpm
Is it a slug off the line because it only start to make power after 3000.
Would this can still be okay for a street car?
yeah i give it a try already have it. i was worried because i saw a dyno sheet on this cam in a corvette and it only started making power at 3000 on the graph. thats what worried me.
